ajriding's avatar
ajriding
Explorer II
Jan 20, 2019
Exit sign battery on TC temporary
I have two 6-volt golf cart batteries, but they sit in the truck bed (in front of the fender), then are wired in.
I also have solar, which is not supposed to be hooked up unless there is a battery connected first (battery keeps things stable).
When truck is away, I also would like minimal power, for one light at night emergency, but this is the secondary concern. I do not camp by removing TC, it's always on the truck when using it.
I want to put an exit sign battery, small lead acid, where the TC battery would normally go in the TC battery box, and have it hooked into the 12 power grid.
There is no point in the expense or weight of a full-size RV battery.
This allows me mainly to leave the solar hooked up all the time without worry of an unstable load or something on the charge controller - which can burn it out.
Has anyone done this, or have a better method they already did?
I'm not interested in thoughts or ideas really, just real-life things that have been done, and pros and con's of it.
Would I be able to power the HippaJacks like this? plugged into shoreline with converter providing additional 12v?
Something like this:
$18 Amazon Exit Sign Battery
  • Is there no compartment where you can install the golf cart batteries on a permanent basis? Even if you have to secure them to the truck bed before you install the camper, you can get forklift type 175 amp connectors to plug them into the camper and your solar array can keep them charged. The enemy of lead acid batteries is allowing them to sit discharged for any length of time.
  • Those are SLA AGM batteries, and as long as it’s a 12 v battery your solar controller should be OK with it. As small as it is AH-wise though, you may not get much jack operation out of it even with shore power plugged in. When I’m lifting my camper with shore power connected, I’m still seeing about 3 amps coming out of the battery. That’s with a much bigger AGM battery that can hold the voltage higher under load for a longer period of time, and a PD4645 converter charger.
    What type of shore power converter charger does your camper have?
  • That will work find. I suspect that battery is used in small ups devices.
  • I don’t think you’ll find anyone who’s powered their hippo jacks off of something the size of a lawnmower battery, but I spose you might find someone who’s tried....
  • I don’t know about that battery. I’d probably consider a Group 22 AGM which is still only about 13 lbs or so. I haven’t done anything like that, but I think it’s a pretty good idea.
