jimh406
Aug 08, 2019Explorer III
I don’t think the Onan’s are any better than others, but generally not very quiet. I’d probably go Harbor Freight 3000 if you want a cheap generator for less (around 700 or less on sale) if you want to go big. I’m sure it won’t be as good as a Honda 3000, but still more power than a Honda 2200 although a lot heavier.
The only issue with running a generator that I’ve heard is startup. Otherwise, most can run on ecomode so a easy start kit is money well spent. Fwiw, even large TCs with lots of appliances only include the Onan 2500 LP version, so I’d think 2500 should be plenty.
44,072 PostsLatest Activity: Aug 23, 2026
