SDcampowneroper
May 20, 2022Explorer
Michael,
For a TT so light ,material shouldnt be more than the existing U bolted to the trailer frame near to the body of the camper , then going forward as long as you need with a X member with a hitch ball 2" ? that goes into your existing trailer tongue hitch to your new hitch
Add a ' lock over mechanism ' that prevents involuntary unhook at the original hitch. Then just make up a wiring extension . Lenghening the TONGUE ( proper spelling ) will decrease tongue weight with no ill but a positive effect as it shifts hitch to axle farther behind.
Towing and parking will be different , as you will need more turning room like a 5th wl rig does. because the axles are moved farther behind.
You write You have a stick welder. I take that as you are a handy guy, so can figure out the rest.
Max
Max
