- FishermanExplorerMy son has an extended run for his Honda, one fill up every 24 hours and changes oil about 3-4 days depending on load.
- mkirschNomad II
GULFMAN wrote:
I have a question for you Honda users.
What is involved in sitting up your Honda to run off a larger fuel supply possibly like a 7 gal. boat fuel tank?
Thanks
Easy answer, get the kit with everything all set up for you. - GULFMANExplorer IIThank you all for the reply’s
Sound like the way to go.
I will add it to my list of improvements. - I have a B.E.R.G.S system for my 2 Honda’s and when it’s used it is awesome…. Siphons nicely, I can fill the 5 gallon external tank without messing with those small generator tanks..
IF you run 2, you get 2 new generator caps, 2 hoses, 1 “T’ connector and a tank… all are quick connect.. - Amazon has several different options.
- jimh406Explorer IIII'm not a Honda owner, but you get a Honda extended run fuel tank and hose. You can find them on eBay/Amazon and other places.
- BedlamModeratorIf you search on extended run Honda generators you will see it is a modified fuel cap with feed to another tank.
https://www.google.com/search?client=firefox-b-1-d&q=honda+extended+run+fuel+tank
