mosseater's avatar
mosseater
Explorer II
Jul 22, 2015
F-150 fan clutch issue: second act
Re: this first thread, today I got a chance to hitch up and try out my new $2700 repair (torque converter, valve body, cooling radiator unit, misc. new clamp, fluids, and gaskets). This was supposed to stop my trans temps from climbing which is the cause of my engine fan engaging at highway speeds.
Turns out, apparently this was NOT the problem, because after about 20 mins towing at 60-65, it started doing the same thing again! Called the dealer before I even got home and explained the situation. They're going to have me come in next Tues. Shop forman was supposed to call with specific questions but never did. Maybe tomorrow.
I have a feeling they're scratching their heads. They should be. So far, being reasonable and polite. Not sure how much longer that will last. I pray for strength.
  • Sounds like they never found the root cause...
    Sure, they know the four first level flags telling the ECU to turn on the
    fan, but do they know what the flow chart looks like for secondary and tertiary flags looks like?
    That is in the logic diagram for the ECU, but the root cause can still be
    in other areas of the thermal rejection system.
    Like plugged to low flow of any of the liquids/lubes/etc to the coolers or
    thermal exchanges
    A good one suggested is that the TC isn't locking up and leaving the TC
    in hydraulic slip, which is normally in the 15% range. Meaning that the
    power input to the TC has a lost 15% due to hydraulic shearing inside the TC
    Seems that they replaced or took out the TC...what was their report on that?
    If me, any time a TC is taken out, replace with a complete rebuilt or new.
    Min would be new friction material in it's clutch
    I'd now suggest taking the main radiator out and have it boiled out or
    flow checked. All three systems of it...assume it has an engine oil and
    ATF section in addition to the engine coolant section...
    and a BIG ETC...air flow to the various radiators?
  • smkettner wrote:
    Can you tell if the torque converter is locked up?
    Exactly.
    Probably 75% of the heat comes from the TC when not locked up.
    Maybe there is a bypass valve on the cooling line/trans that is stuck in bypass?
  • Engine coolant temperature
    Trans oil temperature
    Engine oil temperature
    Air conditioning pressure
    These are the four parameters. Your fan is most likely working correctly...
  • According to tech, only one of four parameters that kick the fan on was trans fluid temp. When it hit the precribed temp of 240, the fan kicked on like it's supposed to. So, trans fluid temp is too high. The cure was supposed to be all the parts they changed. Now that it isn't, not sure what the next step is. I verified myself with my digital IR thermometer that the pan fluid temp is 220 today, so likely at least 240 wherever the sensor is located. Going to be fun to see what happens next. A lot of people looking at the floor while they speak to me, I'll wager.
  • Did they replace the fan clutch? With engine hot you should hear the fan sucking air through the radiator. Probably 5 out of 6 don't work.
  • agesilaus wrote:
    Mechanics and doctors are the two professions that don't stand behind their work. They get to guess and you pay hoping they are right. If they are wrong, they shrug and think of something else to try at your expense. I wonder if a small claims action would work?
    Stay tuned, we may get to find out.
  • Mechanics and doctors are the two professions that don't stand behind their work. They get to guess and you pay hoping they are right. If they are wrong, they shrug and think of something else to try at your expense. I wonder if a small claims action would work?
