Maury82
Aug 06, 2018Explorer
theoldwizard1 wrote:Maury82 wrote:
I got the B.O. hitch setup, with the truck squatting 2" in the rear and 1/2" up front, so the truck actually sits level hooked up.
So it is squatting without the trailer ?????
I would hope not.
I set the hitch up with a trailer attached, and then you try to restore the weight or height back to the front axle that was lost when you dropped the trailer coupling on the truck hitch.
The front was 1/2 inch higher, and the back was 2 inches lower after I got the Blue Ox tension bars adjusted with the trailer hooked up.
The truck is normally jacked up higher in the rear than the front, so after everything got set up, the back and front looks even.
44,070 PostsLatest Activity: Aug 07, 2026
