Terry_25
Dec 30, 2016Explorer
F-250 tire pressures
2016 F-250 gas crew cab. GVW is 10,000lb. Weighed it on the way home and it scaled a little over 6900lb. Door jam says tp should be 75 in front and 80 in rear. Did fine until it got cold and then the TPMS icon lit up. Dealer says 75 and 80 necessary to make the light go out. Did well all summer at lower pressure (68psi all around) and no light. Even loaded with a 30 ft tt Iknow I won't be over 8500lb. Anyone know where I can find a load/inflation chart for LT245/75R17 tires? Thanks.
