- 2112Explorer II
dragr1 wrote:
It swayed more than I liked in crosswind. The 35'Outback was too long for it. Not enough dog for that tail.2112 wrote:
See Sig
Previous TT was an 8500lb 2011 Outback 277RL. The FW tows soooo much better.
How was the truck pulling that Outback? - AlmostAnOldGuyExplorerWith truck in signature towing 28' at 8k loaded. Well within specs including receiver which is rated at 1150.
Note this is Max Payload (LT tires, stiffer suspension, heavier axles). If you are towing relatively heavy I recommend LT tires and ensuring you are well within your payload and axle ratings per yellow sticker.
Good luck,
Stu - arush19ExplorerGrand Design Imagine 2950RL. 33 feet.
- TomG2Explorer
3oaks wrote:
I didn't see where anyone here suggested towing above the rated capacities of the truck.
My point was that the engine is the last thing to look at, not the first when it comes to towing. I have looked at some powerful pickups that had unbelievably low real world towing capabilities. - dragr1Explorer
2112 wrote:
See Sig
How was the truck pulling that Outback? - 2112Explorer IISee Sig
Previous TT was an 8500lb 2011 Outback 277RL. The FW tows soooo much better. - 3oaksExplorer
TomG2 wrote:
Absolutely true, but I didn't see where anyone here suggested towing above the rated capacities of the truck.
The correct answer is tow within your chassis limits. Most modern pickup have enough horsepower. Payload is another matter. Put 3,000 pounds of payload in s pickup designed for 1,500 pounds and I don't care how many turbochargers it has. - jbarkleyExplorer2014 F150 3.5 Towing 7000 lb Keystone x-lite 5th wheel 11.5 mpg avg
- TomG2ExplorerThe correct answer is tow within your chassis limits. Most modern pickup have enough horsepower. Payload is another matter. Put 3,000 pounds of payload in s pickup designed for 1,500 pounds and I don't care how many turbochargers it has.
- dragr1Explorer
RSD559 wrote:
Towing is much less stressful when you stay below your towing limits. I tow our trailer for fun and relaxation, not for thrills.
I definitely agree with that
