CaveRun wrote:
wvabeer wrote:
I have a 2013 f150 7200lb ecoboost supercab 6.5 bed and wondering if anyone has this combo with the Camplite 6.8 ? How is your mpg? does it feel overloaded? Just doing a little searching for info before I buy a truck camper.
You could haul it with your Ford just fine without any problems!... If I was you, I would install airbags... Don't know what you plan to tow when you have the TC loaded.
Here's a quote from Livinlite.com website.
Our 6.8 model was designed specifically for short bed, half-ton trucks. The 6.8 is a self-contained unit with all the amenities of a much larger truck camper while still fitting into a 6-foot, 6-inch bed with no overhang! This camper slides all the way into the truck bed, meaning that it can also be utilized on larger trucks.
Link...Scroll down the page to read the info I posted.
Camplite Ultra Lightweight Truck Campers
That camper was designed for 1/2 ton trucks!
I have a 2002 F-150 and haul a Sunlite hard-side TC and pull a pontoon boat when we go on a fishing/camping trip... I have airbags on my truck, because the truck will squat when I load the camper down with camping/fishing gear, and hook up the pontoon.
I put 60 to 80psi in the airbags to bring the truck back up to level.
Again, your truck will do just fine with that TC, because it was designed for 1/2 ton trucks... Call and ask them if you need to!.. That way you will get the right answers instead of someone telling you a F-150 won't haul it!
I have an aluminum trailer to haul 4wheelers or a side by side. less than 100 lbs tongue weight.
