CaveRun wrote:
Even the 8.6 Camplite Truck Camper is designed for some 1/2 ton trucks, and it also mentions a Ford F-150.
Yeah..... the F150 HD with the 8200 GVWR and the bigger 4800 RAWR with LT E tires and wheels would be a good choice.
The '00 to '06 1500HD GM with a 8600 and 6084 RAWR 6.0 4L80e with E tires and 8 lug wheels is another 1500 that can do the job.
And don't forget the 1500 Dodge Mega Cab Hemi with 8510 GVWR and 6000 RAWR 3.92 axle with E tires and wheels and another good choice for the 8.6 Camplite.
However the OPs F150 as many std duty 1/2 ton trucks doesn't have the capacity (Tires/wheels and rear suspension) to carry the 8.6 TCs 2000 lbs dry weight let alone a 2500 lb + loaded weight.
