spud1957 wrote:
The info demiles provided is correct. Read Ford's 2017 F150 Towing Guide notes on page 3 for 5th wheel towing;
1.Calculated with SAE J2807 method
Note: Trailer king pin load weight should be 15% of total loaded trailer weight. Make sure vehicle payload (reduce by option weight) will accommodate trailer king pin load weight and weight of passengers and cargo added to towing vehicle. Addition of trailer tongue load weight and weight of passengers and cargo cannot cause vehicle weights to exceed rear GAWR or GVWR. These ratings can be found on the vehicle Safety Compliance Certification Label
F150 Towing Guide
Yep! Another Ford slide of hand, first is was stripper base trucks less spare tire and rear bumpe, now you can carry/tow an 11,700# 5er, BUT you need to keep the pin weight to 15% of the 11,700# or 1,755#. Now as a 5er tower, towing a 5er with ONLY 15% pin weight is going to be one rough ride, it will chuck like crazy! That and to get to 15% on almost all 5ers you would need to load heavy behind the axles, this could make for an ill handling 5er.
No that is not the total available payload of that F150, BUT they know there are other things that eat payload, passengers, fuel, hitch, and stuff!
Now that 11,700# 5er with a realistic 20% to 22% that would be 2,340# to 2,574# pin!
