Crowe
Jul 07, 2016Explorer
How is the braking? Does it stop ok or is braking poor? If you pump up the pedal with the engine off and hold pressure on it for a minute, does it sink slowly?
Stops fine but as stated pedal is like a rock when truck not on.
Since the OP did not mention any loss of brake fluid I would rule out wheel cylinders, brake lines and hoses leaking..
Not mentioned because I really don't know. Hubby being the "let's go for the most difficult thing first" engineer type HASN'T LOOKED! :B If I can hobble out to the truck I'll check myself (nursing a bad foot). Usually that would be something I would think of. Hang tight. Now I'm curious.
Checked the fluid. Mind you I'm about 5'5" so I'm not "short", but seeing into the reservoir was a bit a challenge!
Fluid is dark yellow and up to the max line.
