rangerheave's avatar
rangerheave
F150 EcoBoost question
I just bought an new 2013 F150 EcoBoost with 5.5 ft bed, Max Tow package and pull a Keystone Passport 3050BH Travel Trailer. I am interested in hearing peoples feedback on my rigs abilities to pull my trailer as well as put a 2012 Polaris Sportsman 400 which weighs a little under 700 lbs.
If I pull my trailer with the 4wheeler in the bed is this a dangerous combination by putting too much weight on the rear of the truck? I would add that I have a weight distribution hitch and anti-sway bar on the travel trailer.
Thanks in advance for your input. I look forward to hearing your responses.
  • rangerheave wrote:
    factory specs on my travel trailer state that hitch weight is 625 lbs. My asumption is that "Hitch weight" is the same as "tongue weight"?.
    Yes, but your hitch weight from the factory is very misleading. It doesn't include the weight of the battery, propane tanks, any other dealer installed items, water in tanks if you carry it, dishes, clothing, bedding items, etc.
    You want to weigh your rig to know a more accurate hitch weight, you would be surprised how those hundreds of extra pounds add up so quickly!
    Any easy way to estimate is figure out what percent of your total trailer weight is on the hitch from the factory. Usually between 12-15%. Then figure out your total GVWR on your trailer and multiply it by the same percentage as your factory hitch weight. That will give you a more reliable number until you can actually weigh it.
  • The max tow is not going to help with the quad, you need the max payload package which is not the same. I suspect you won't have enough payload for what you want to do.
    Check your door sticker for payload rating. If the weight of the quad, people, gear and tt tongue weight fit within the payload # then you should be ok. You could also load the truck with people, gear and the quad and go to a scale. Subtract scale weight from GVWR and what you have left is available for the hitch and trailer tongue weight.
  • factory specs on my travel trailer state that hitch weight is 625 lbs. My asumption is that "Hitch weight" is the same as "tongue weight"?.
  • Shorter wheelbase truck and a long TT......plus a tongue weight of, I'm guessing 900lbs? and a 700 lb four wheeler? That is allot of weight !
    You post you have the Max tow package (good thing), as the others have wrote, check your door for payload numbers. I have to believe you will very close if not over on the payload.
  • SuperCrew Lariats generally have low payload, unless you have Max Tow. I suspect trailer tongue weight alone is close to maxing out your truck.
  • Ill have to look. Not sure if this has any effect but I forgot to mention that my truck is a Super Crew Lariat.
  • What is the payload of the truck (on the door sticker), minus the 4 wheeler and tongue weight, and hitch weight? I'm looking at new F 150s now. Some of the payloads are disappointing, like 1100 lbs.
    I have an 06 supercab that has a payload of 1750 per sticker.
    You may run out of payload a lot sooner than you expect.
