Turtle n Peeps wrote:
Thoughts?
When you're passing twice the amount of fuel and air of a normally aspirated engine, turbocharged engines will get hot very quickly.
When you have a very small engine and cram it full of air and fuel you won't have much of a duty cycle.
When pushed to the max in hot weather the EB will get hot and derate to save itself.
A premium fuel will give you a slight cushion from the derate. Octane boost will give you even more.
Totally agree. You making a basically small engine do something that a bigger gas engine or diesel do with less stress.Also the EB's fuel efficiency drops off under load, you have to drop it down in gears to save the engine
