CantCampEnuf's avatar
CantCampEnuf
F150 ecoboost towing
Just got back from our first trip with new truck/trailer combo. I am impressed. The truck was very comfortable to drive, got good gas mileage, felt comfortable towing, had little sway, and had power to spare ascending 6% grades.
Questions: I always have driven my Fords in tow/haul, then downshifted when descending grades over 5%. I have not downshifted ascending at all. ON one climb coming out of Camp Verde...We got a message on dash display saying engine was running hot and would downshift to lower gear. It did and engine temp dropped dramatically. I don't know if that was normal, or because we were climbing 6% in tow/haul, but forced to ascend slower than we wanted due to traffic. Note: truck had sat idle run after filling up with gas/getting food for kids for 20 minutes right before climb started and we are in AZ, it was 98 degrees. Thoughts?
Also, there is drive, M, 1 and 2. Along with tow haul. Let me know what you cruise at. We are pulling 9k, 32 ft.
  • Thoughts?
    When you're passing twice the amount of fuel and air of a normally aspirated engine, turbocharged engines will get hot very quickly.
    When you have a very small engine and cram it full of air and fuel you won't have much of a duty cycle.
    When pushed to the max in hot weather the EB will get hot and derate to save itself.
    A premium fuel will give you a slight cushion from the derate. Octane boost will give you even more.
  • What year is your truck?
    Also do you buy 91 octane gas while towing?
    91 octane is recomended while towing to allow the engine to run leaner, and thus will give better mileage.
    Did you somehow have the engine in manual shift mode? This would have prevented it from downshifting on it's own when heavy throttle is applied, thus the message on the dash. I would think that having it in drive, and then turn on the tow/haul mode, it would still be shifting itself.
    However if in M mode, that requires upshifting and downshifting with the up and down buttons, and the transmission is not trying to change gears on it's own. M mode is what I used while going down a 5% grade in city traffic, where the speed limit is 35 MPH, and all the cars in front of my have their brake lights on! I just downshift, and coast down the steep hill. Then hopefully remember to shift back into D at the bottom of the hill, so that the transmission will select the gears for me.
    Fred.
