wdgold
Jul 23, 2017Explorer
F150 Fx4
Anyone out there pulling a 5ver with a F150 Fx4 screw with 5.4 Thinking of going with a slightly heavier unit than I had.
MitchF150 wrote:
My payload is #1900 and I have #4050 rear axle rating.. Wouldn't want to tow a 5th wheel with it.. Just too dang heavy for what I'd want in a 5th wheel..
I've got 'XL' rated tires rated at #2833 @ 50 psi, but they are 20" tires, so maybe that's the difference?
Anyway, do what you need to do and if it works for you, that's all that matters... :)
Good luck!
Mitch
wdgold wrote:
My Payload is 1300#, my guess is If I don't exceed that with pin weight, fuel, passengers etc I should be fine correct?
Yes, that is correct. However, you will not find much of a FW, with less than 1300 lbs loaded pin wt. If you can stay under RAWR/tire ratings you may get by with the 150, but not really the right tool for the job.
Jerry
Steeljag wrote:
Start by checking the trucks CCC (sticker located on drivers door), then pin weight of any FW your interested in !
Good luck !
