thomsExplorerNov 20, 2017F150 tow vehicleHi All, I need a little advice, just got a 2001 ford f150 ext cab. with a 5.4L motor. GVWR 6300 lbs. I think it has the 3.31 rear end. it also has the full towing pkg. hitch,shocks,cooling,etc. lo...Show More
atwowheelguyExplorerNov 20, 2017Check the door sticker. The axle code is probably on it. Also check the payload. Payload = maximum weight of occupants and cargo.An estimate of the maximum trailer weight isMax trailer weight = (payload - wt. of all occupants and cargo - 80 lbs. hitch wt.)/0.13Example: Trailer wt. = (1400 - 600 - 80)/0.13 = 720/0.13 = 5538
Related ContentWho misses the Tow Vehicle discussions?Ford f150 PayloadTow vehicle F150Tow vehicleMotorTrend F150 Lightning Tow Test
