Hi All, I need a little advice, just got a 2001 ford f150 ext cab. with a 5.4L motor. GVWR 6300 lbs. I think it has the 3.31 rear end. it also has the full towing pkg. hitch,shocks,cooling,etc. lo...
Truth is. Only you will know how well it tows. With the information you have given. You tow capacity is prolly closer to 6800lb. Which isn't that bad for that year 5.4.
You will need to be between 5500, and 6000lb loaded. there are lots of TTs that will fit in that weight.
I had a 2002 Expedition with the 5.4, and 3.55. The Tt I had then was in the 6K range. It did a great job.
