ROBERTSUNRUS wrote:
BenK wrote:
There is nothing wrong with a half ton...as long it is used within
it's ratings...but...many insist on a 'half ton' badge...even though
they need a higher class TV...so all or most of the OEM marketing
folks have 'fake half ton' that is badged: "half ton", but has
'some' components and GVWR in the next higher class truck...
I own two half ton pickups
WHICH F150 half ton do you own?
They range from +6K GVWR up to +8K GVWR...which I call the 'fake
half ton'....a 3/4 ton normally has a 8.6K GVWR
The 'regular' half tons has 'P' class tires (passenger class
tires) that needs to be de-rated a min of 9% when used on pickups
and SUVs.
Fake half ton pickups has the next higher class tires, 'LT' class
'Regular' half ton's has +4K RGAWR...where as 3/4 ton has +6K
RGAWR...as does 'some' of the fake half tons at +5K up to +6K RGAWR
Tell us which class tires and RGAWR of your half ton?
My Silverado has a 6,200 GVWR and a +4K RGAWR
My 3/4 ton Suburban has a 8,600 GVWR and a 6K RGAWR
ROBERTSUNRUS wrote:
BenK wrote:
+4K RGAWR vs +6K RGAWR
Bigger frame
Higher class tires
and a big ETC...unless you are referencing the fake half ton for folks who
insist on only owning a half ton...
:) Hi, could you explain what you mean by a "Fake Half Ton"? And what is wrong with owning a half ton? I own a half ton / F-150 is there a problem with that?
:) Hi, I guess according to you, I have fake half ton. If that's the case then I take it fake means good. 2014 F-150 super crew cab, Ecoboost, 4X4 Off Road, Max tow, 7,650 Lbs GVWR, 1745 payload, 3750 front axle, 4050 rear axle, 11,200 lbs tow rating, and LT tires. But this is what I needed/wanted for towing my 6,300 lb GVWR Airstream.
Me too. And I LOVE IT! The power, the ride, the mpg. I was skeptical. After several trips, payload is too high aside, I am very pleased, impressed and more confident in this truck then any I have owned for towing, even better power than the v10 I had in my f450 jayco.... so yes, if you can afford and want more truck, it might be more IDEAL. but these suckers can tow.
