TyroneandGladys's avatar
Jun 29, 2015
f150 versus f250
What is the advantage/disadvantage of a f250 over a f150 if the drivetrain are the same and the tow capacity on both 15,000lbs? Would be used to pull a 27 foot travel trailer not a 5th wheel.
Thanks
  • +4K RGAWR vs +6K RGAWR
    Bigger frame
    Higher class tires
    and a big ETC...unless you are referencing the fake half ton for folks who
    insist on only owning a half ton...
  • Payload capacity.
    The maximum payload capacity of a new F150 is 3300lbs, if set up correctly.
    The payload range of an F250 runs from 2950lbs to 7050lbs.
