3iron's avatar
3iron
f250 4x4 crew cab weight
Looking at this this truck but wondering what the weight is. Can anyone help me with this?
Thanks for looking.
  • Moved to Tow Vehicles from 5th Wheels
    Admin
    RV.net
  • Golden_HVAC wrote:
    What year of truck?
    Gas or diesel?
    The 7.3L 4X4 F-250 crewcab was only about 800 pounds less than the GVWR, so be careful, most diesel trucks do not carry a lot of weight before going over the GVWR. My 95 Windstar could carry more weight than a 7.3L Excursion or 4X4 crewcab F-250!
    While the 7.3L was a wonderful engine, it was also a 700 pound option over the lightweight inline 6.
    If you want to carry something heavy, keep looking. The F-250 diesel was not able to carry very much cargo, before going over the GVWR.
    After 2005, the GVWR went way up. In 2004, the F-250 GVWR was only 8,800 pounds, while a 2005 is around 10,000 pounds, depending on options of course. A light gas engine 2 WD 2 door has a lighter GVWR than the crewcab diesel has.
    Good luck!
    Fred.
    so you telling me that your windstar van is a better tow rig than my 2002 F250 with the 7.3?
  • 3iron wrote:
    US out west; Real close, thanks.
    Real close to what?
    You implied in this thread you were "looking at this truck" but in an earlier thread you stated you bought that truck.
    So color me :h
  • 7240 lbs with me in it, plus tool box and tools, floor jack, etc.
    4x4 c/c 6.2
  • What year of truck?
    Gas or diesel?
    Good luck!
    Fred.
    Thanks for looking.
    Read the label on your door pillar that says "Combined weight of occupants and cargo must not exceed xxxx pounds"
    Subtract "xxxx" from the truck GVWR (on another door label) and you will arrive at the weight of your truck as it left the factory.
  • Mine is about 7980 lbs. 6.7 4x4. Payload is about 2020 lbs.
