Bedlam
Jan 07, 2014Moderator
I agree with Redsky above. The Sterling 10.5" rear axle used in the SRW 250 and 350 is rated for 9750 lbs. Running 245/70R19.5 tires will give you about the same 33" height as the 265/70R18 tire option. The 245/75R17 tires are about 31.5" tall. Going to the 19.5" rims and tires can get you over 4900 lbs of capacity per wheel based which tire you choose.
44,066 PostsLatest Activity: Apr 15, 2026
