Gdetrailer
Jan 09, 2014Explorer III
8iron writes “The point is that with certain option packages, mechanically it IS an F350. IF one chose to, one could exceed payload rating with an F250 and not exceed a single design rating of any component under that truck.”
It took me a while to locate the info BUT you guys are wrong, you are only fooling yourselves.
The F250 while it does use a 10.5” Sterling axle HOUSING, the axle of a F250 is NOT the same INTERNALLY as a F350.
The internal axle is not the same size (kindly notice that the 1.36” minor shaft size of a F250 is SMALLER than the 1.5” minor shaft size of a F350), the diameter over the splines is ALSO different (F250 is 1.50” and F350 is 1.57”) which means the internal parts are not the same and who knows what else is different internally..
There is good reason as to why a F250 axle shaft has 35 splines vs F350 which has 37 spline. Try putting a fitting 37 spline shaft into a 35 spline carrier, not going to happen. And for a good reason, the shafts are different size and have different capacities and so will other internal parts..
I guess I am only one of a few folks who have noticed these differences…
I would bet that if you ordered F350 internal axle parts that they would not fit into a F250 axle without changing every internal part..
Please note in the quote below that a F250 AXLE is rated at 6200 lbs and a F350 axle is rated 7280 lbs (spring and axle ratings ARE GIVEN SEPARATELY)..
If what you say is correct then why is the AXLE RATED DIFFERENTLY between F250 and F350?
Why would the F250 have 35 spline vs the F350 with 37 spline?
If what you say is true then BOTH F250 and F350 would have the exact same axle rating AND the same number of splines AND the same axle diameter. NONE of that is true.
Pretty much stands to reason, Ford like any other manufacturer is simply not going to spend more money than needed. Bigger, heavier internal parts COST more and there is no sense putting those in a vehicle unless they are really needed. If it was not so then Ford would have no reason to even build a F350, they could just use one heavy duty truck with different tires. If it was as simple as you say then Ford would simply slap a F350 sticker on any truck.. But they don’t.
Same goes for the springs, if one is observant you will notice that there ARE different springs with different number of leaves IN THE PACKS.
The simple answer is NO, you cannot make a F250 into a F350 by upgrading the tire size, you really would have to CHANGE THE AXLE AND SPRINGS along with the upgraded tire along with any other suspension parts which are not the same. The cost of aftermarket parts would far exceed the cost difference between a F250 and F350.
The body, frame, engine, transmission, interior may all be the same between F250/F350 but the suspension parts is not the same.
I think what confuses folks is the order/axle codes are the same and the PHYSICAL OUTSIDE DIMENSIONS are the same but I guarantee if you slip under some new trucks on the lots and write down the axle PN tags of a F250 and F350 you will find completely DIFFERENT Ford part numbers on those tags.
If you need the higher capacity of larger tires (remember the default 17” tire has 3195 lbs of capacity) then you NEED to buy a F350 and be done with it instead of pretending.
If ride height is an issue then changing the rear blocks will drop a F350 down to a F250 ride height however keep in mind that you may need to rework the drive shaft angles.
F250/350 Comparison
From the link above..
"Here is some info I posted in some other forums, I pulled the info straight from the factory fleet manuals from the ford site.
2011 Model Super Duty
F250 SRW"Sterling" axle rated @ 6200 lbs___springs rated @ 6100 lbs--axle shaft dia 1.36"min - 1.50"maj - 35spline__brakes--13.39"
F350 SRW"Sterling" axle rated @ 7280 lbs___springs rated @ 7000 lbs--axle shaft dia 1.50"min - 1.57"maj - 37spline__brakes--13.39"
F350 DRW"Dana 80"axle rated @ 9000 lbs___springs rated @ 9000 lbs--same as above__brakes-13.39"
F450 DRW"Dana 80"axle rated @ 9000 lbs___springs rated @ 9000 lbs--same as above__brakes-14.53" front - 15.35" rear
F250/350/450 front axle rated @ 6000 lbs for 4x4 - 5250 lbs for 4x2 -- all brakes above are rear sizes front are 13.66" except F450
The actual axle housing diameter is the same 3.5" on SRW 250 AND 350. 4" diameter on F350/450 DRW."
F250/350 spring comparison
Text from above link..
"2011 F250/350 Leaf Spring Question
Oh guys, first real post. I'm interested in finding out some info. Ford Engineers stated that the reason they went with a 2+1 rear leaf spring design on the 2011 Super Duty was to reduce weight, improve the ride. Upon researching the various Super Duty's I've seen the following.
First, when I purchased my 2011 Lariat F250 6.7, the sales person said the only difference between the 250 and 350 was 1 extra leaf spring (2 total). However, i'm finding out some interesting facts.
First, I've seen at least 5 2011 F350 (Crewcab) trucks (all Lariat models) that have a 2+1 (3 total) Leaf Spring setup.
I have also seen at least 4 2011 F350 (Crewcab) trucks (all XLT, some with Gas and some with Diesel) with a 3+1 (4 total) Leaf Sprint Setup.
And of course the straight frame F350 has something like a 9 leaf setup.
So, why do the F250s have a 2+1 Leaf setup as well as the F350, and some XLTs have a 3+1 while lariats have a 2+1.
Also, is the spring rate the same? are they stiffer on some trucks?
NONE OF THE TRUCKS LISTED ABOVE HAD THE FACTORY OVERLOAD SPRING ON TOP. There are all part of the regular leaf stack."
Another F250/350 comparison
"Package for package, tires for tires, wheel base for wheel base the trucks are identical. The main difference is the gross vehicle weight, the small differences for the F350 SRW, a spacer block under the rear axle spring pack, larger diameter rear axle shafts with finer splines, rear helper springs, and hydro-boost breaks, Price. Again, package for package, tires for tires wheel base for wheel base, gear ratio for gear ratio, the ride and fuel mileage will be the same."
Ignore the facts and continue on dreaming that a simple tire change makes a F250 into a F350...
F250/350 Comparison
44,066 PostsLatest Activity: May 13, 2026
