BenK wrote:
My advice i empirical both in careers & hands on, plus college and common sense are my qualifications...toss in older than most on this/these forums (70 next year). For here, my first career in Industrial Controls, Robotics, Process Controls, Factory Automation and military stuff. No automotive, but people movers
Gotta add first...decide if you believe in all of the OEM's 'ratings', 'specifications', etc. If not, then academic this thread. If yes, then research and bone up on 'your' OEM's specifications, ratings, limits, etc...plus your states rules of the road and the states you plan on driving to and through
Another point is that all things designed, engineered, etc are not for the good days out there...but for the day Mr Murphy crosses your path (and it is NOT always the 'other guy' that he touches).
Either you have the right sized stuff and adjusted correctly spot on or NOT. No time to go back to the store for bigger/better/etc, nor re-adjust
That is to 'manhandle' the situation enough to regain control or maintain control of the situation. Otherwise just along for the ride
There are: 'can do it', 'should do it'....to 'rated for it' via the OEM's specifications, which is basically their CYA for their liability of their product...AKA...their contract to you, the owner/driver. The only person responsible for the setup is the driver...even if they did NOT choose the components that makes up that setup. Nor any of us advisors on these freebie forums. We have no skin in 'your' game...now is there any liability to us.
A think can be designed to be safe in all situations, but then it would not be affordable to civilians. Heck even military stuff has their specification limits too, but way more than a similar civilian version.
Confusion on most and on this have to make this point clear, as many do NOT understand corporate parts bin design & choice of components & systems.
As you go up in class TV's, the volumes diminish greatly. So to have specific, say rear axle assemblies, for everything above the lowest class, half ton, would be cost prohibitive or too costly.
Why many/most "3/4 ton" and "1 ton" TV's has same/similar rear axle assemblies from their suppliers (another OEM) and the TV OEM adds 'stuff'...like brakes (backing plates, calipers, etc)...but the base axle assembly is the same between them. That is where I think most of the confusion and conspiracy theories arise from...and it is based on a bit of truth because of the "corporate parts bin" methodology
This goes with tranny's, frame's, suspension part's/system's, etc
Then the fact that most TV OEM's use the exact same basis sheetmetal cab/body/bed/etc from the lowest class up to most of the higher classes. So they 'look' the same with no difference to many...too many
Most seasoned owners of TV's who actually use their TV's as 'trucks' for either work or towing/hauling heavy...knows more than the average salesperson. Why for trucks, I'll mainly go to a broker for semi's and/or commercial trucks. They actually know much more to IMHO, experts
The new yellow label is a step better, but am still of the opinion to actually go out and weigh your setup. Both empty and fully loaded. Otherwise you really don't know where you are in reference to 'your' setup's ratings
IMHO, go with this generic formula using actual weights: GCWR >/= TV + Trailer + stuff (hitch, people, pets, cargo, after market, etc, etc, etc)
Finally...an oddity to me...folks want to push their limits, advise others to do so because they have been doing that for years with no problems...but then when it comes to a used vehicle...miles matter and always looking for abuse or lack of maintenance... Well if the previous owner pushed the limits and beyond, even low mileage can be risky...to if they didn't and stayed below the limits...a higher mileage TV would be fine... Baffling that to me...
Go out and actually weigh your setup, fully loaded and empty, axle by axle...
bighog01 wrote:
New F350 SRW that I'm considering says 3326 lbs on the payload sticker with a 11500 GVWR. I asked for this info before the dealer had it brought in from another dealer. Salesperson and fleet manager say that its actually 4164 lbs because the factory invoice says the trucks shipping weight is 7336 lbs. Now I'm sure that's weighed with minimal diesel I. The tank. Isn't the door sticker the law? I always thought so. I'm not obligated to buy this truck and I have no deposit on it. Right now I'm not feeling comfortable hitching my Fuzion to it.
Consider two similar trucks. Truck 1 is a 2014 Duramax 2500 that was used it's entire life to pull a 12000 lb RV with a 2400 lb pin weight which put the truck 800 lbs over its GVWR. Truck 2 is a 2014 GMC Duramax 3500 dually which was used its entire life to pull a 22000 lb rv with a pin weight of 3500 lbs. It was never loaded to its GVWR. Obviously truck 1 was abused by your view of things but I wiuld be more interested in buying truck 1 than truck 2 if they both appeared to be well looked after.
