I was in construction, owning the company for 35 years.
Yes, religion and politics are out.
're the 10,000 lbs on 245 rubber. I can't in a single wheel rig, put 10,000 lbs on the 245-70-19.5 tires rated to 5400 lbs that were on the front of my dump truck! Max, 4750 per tire, or 9500 per axle in this state. If you come, that is A alL you get here. You can change rim Siam to 22.5 or even 24", you will get a max of 9500 lbs on those tires. Manufactures engineer ratings be danged.
The engineer that as specs the max load per tire on the road, is the one that designed/engineered the road! The engineer ratings from remanufactured are not enforced by you state Patrol, or mine!
I'll be looking up Texas weight laws on a computer to verify this. I know what federal law states.....
Marty
