Cummins12V98 wrote:
4x4ord wrote:
Cummins12V98 wrote:
4x4ord wrote:
I'm looking at the technical specs of the 2020 Super Duty and found the F450 4x4 has a curb weight of 8,587 lbs which is 855 lbs more than the F350 SRW crew cab long box with the 6.7 Powerstroke. The SRW long box crew cab can be equipped to have a gvwr of 12,400 lbs. The F450 has a GVWR of 14,000 lbs. The payload of the F450 appears to be only 745 lbs more than that of a SRW F350 crew cab long box.
YEP but that is "IF" you "BLINDLY" go by the 14k GVWR that is restricted to Class3 by licensing and Insurance.
Simply look at the RAWR of each. License your truck to what it actually carries and carry on.
FACT, my 15 RAM DRW has a GVWR of 14k. My SAE RAWR is 9,750#. My Factory front axle weight is 5,250# +-. So HOW IN THE HE!! can I load my rear axle to it's RAWR and NOT be overloaded???
Folks it's it's all a numbers game! FACT is my loaded weight is well over 15k. I am perfectly "LEGAL" by licensing my truck to what it's loaded weight is. Another thing to consider is my tires have lot's of capacity even at those weights.
Bottom line, use the brain GOD gave you!
I'm not buying this numbers game argument. Why would Ford publish lower payload numbers than what they feel their truck is designed for? If it was to get around registration laws I would think they would offer the lower gvwr stickers for the f450 for those who this would affect. If I'm a heavy hauler and need a truck that can handle a 6000 lbs pin and Ford tells me their F450 can only take 4500 but Ram says they can handle 6000 I'm going to buy a Ram.
My point is the payload is false! A 450 in reality can handle way more weight than what the class3 limits it to with 14k GVWR.
My door jamb only gives 6k front and 9,750# RAWR. It does not have a 6k capaciity on paper but it sure does with using the RAWR.
SIMPLY PUT I can’t tow my RV and stay within its Class3 14k rating.
Someone please tell me why it’s an issue to load my rear axle to its SAE 9,750# rating that will place me at an actual weight of 15k. Also why have that RAWR if it’s going to put me over that magical 14k rating?
The idea is supposed to be that the GVWR takes into account all the components of the truck. If you're going to ignore ratings why not just load your truck to the weight rating of the tires? (in Alberta I believe I'm legal so long as I'm within my tire's ratings) It used to be that the F250 (maybe still is) had the same axle, tires and rims as the F350 SRW. Even though it seems stupid to me, Ford limited the GVWR of the F250 by omitting the overload spring of the F350 SRW and putting a 10k sticker on the door. In the case of the F250, loading the truck to the axle rating overloads the spring carrying capacity. If you're going to overload something I guess overloading your springs is the thing to be least concerned about.
