4x4ord wrote:
Here is the specs for the 2020 super duty pick ups link. What specs in particular are you seeing that suggest the F450 is more capable? I see the 4.30 axle does give it the highest tow rating but I don't think there are any RV'ers who need a higher tow rating than what an F350 offers.
I'll post this link again... These are the
Full 2019 SuperDuty Specifications. If you take the time to read them, you'll see the F450 has an entirely different front axle, heavier rear axle internals, and bigger braking system all around. When Ford switched to the aluminum body, the frame did become common with the F450 once again, but it's all around stiffer than the previous generation. Plus the wide-track front axle and 19.5" wheels.
Also, one more bonus with the F450... You can get a eLocker with 4.30 gears, but not with 4.10 gears as that ratio only gets LS as an opion. So if you must have an eLocker, on the F350 you are limited to 3.55 gears which is good for 36k combined vs 41k+ for the F450/4.30 gears.
These are relatively small differences, but enough to matter for some folks, and it's nice to have the option. It may not be for you. That's fine. Don't buy one then.
