Michelle.S wrote:
Have a question: If both the 350 and 450 have the same GVWR of 14000 Lbs and the 450 is a heavier truck, don't know by how much, but doesn't it stand to reason that the 350 can carry more pin weight, thus a bigger Fifthwheel??
If you go by GVWR the F350 has a little more payload. If you go by axle rating the F450 front axle is rated about 400 lbs more than the front axle of the f350 which about accounts for the weight difference. The two wheel drive F350 the highest rear axle rating and has the highest payload rating.
