zb39
Apr 05, 2023Explorer
What Grit said is correct. How much further do you think you would really go with the stock duals VS super singles when loaded. I put my money in a full Kelderman air suspension, front and rear. I also went with a CM skirted bed, steel. Weight is not an issue, steel cost less, I can attach my fast guns directly to the steel rub rails. I'm in my camper as I type this. Good luck.
