myredracer
Apr 28, 2014Explorer II
JJBIRISH wrote:
Did you do the most important weight for the trailer loaded for camping… that would be the heaviest wheel… not all trailers weigh the same side to side or front to rear on the road…everything is based from the heaviest wheel… you could find you have one tire overloaded and the others underloaded…
One scale was a large platform that took in the complete truck + TT combined and the other was both TT axles together. Both results were essentially the same. You do bring up a good point. It would be good to know the loading difference between wheels. Shouldn't be a problem with our load range D tires? On one of the scales I can easily run through on one side or the other.
