Z-Peller
Oct 18, 2020Explorer
You are saying no power to fan. Do you mean that you have been using a tester on the wires?...or that your fan has not started running?...Depending on model your Fantastic fan has direction rocker switch, 3 speed knob, thermostat knob. Do you have all those controls turned on?...if wires are dead with tester then I would try to determine if they are prewired from one of the nearest ceiling lights and are capped off there and need to be connected or as suggested check 12v fuse panel for fan circuit fuse needed.
44,070 PostsLatest Activity: Aug 05, 2026
