rexlion wrote:
A Fantastic or Maxx fan on high could do a complete change of air in a small TT within just a few minutes. Even on low or medium, it will draw a very nice breeze in through your windows. So whether that would be enough for you depends on the temp and humidity levels outside, and your personal comfort level.
Personally, just sitting around in the TT on a reasonably dry day I am ok up to about 85 degrees during the day, but I like it to be below 75 when I try to fall asleep. But if I were in the Pacific NorthWet, I might feel differently! I hear tales about your humidity levels. I don't like feeling sticky or being under sheets that feel damp, and AC dries the air so much.
If you're trying to economize, install a 3 speed fan along with a MaxxAir vent cover so you can leave it open , even in rain. I think this item is well worth having for comfort's sake even if one has an AC as well, because 90 percent of the time I can be comfortable with just the fan-induced breeze (and I tire of the AC noise).
But if you decide to get an AC, have you considered something like an 8000 BTU window unit? Much cheaper than a rooftop unit. Some folks install them permanently through either a window or a hole cut in a wall.
This.
You definitely don't need a large AC unit. You need one small enough that it will run at least one-fourth of the time that it's on. That's what it takes to keep humidity down. You also need to be able to run the fan on high, to move enough air through to keep the AC from forming ice on the evap coils.
