- ib516Explorer II
crcr wrote:
I'm wondering when one of the Big 3 US truck manufacturers might market a gas V-8 with turbo(s) in their 3/4 and 1 ton pickups. That's one gasser I would consider for towing ...
Probably because of the horrid mpg they would get.
In a recent test, the "e-beggars" aka TFL guys put an Expedition (3.5 V6 EcoBoost) up against a GM SUV with a 6.2L V8, both towing a 7000# trailer over the same route. The huge GM V8 beat the "Eco"Boost by 0.5 mpg, 9.1 for the 6.2L vs 8.5 or so for the 3.5L turbo Ford.
If a tiny 3.5L V6 (remember that's ONLY about 217 cubic inches) gets 8.5 mpg pulling 7000#, what would a gas V8 turbo get? 3 to 5 mpg?
There's a reason they are sticking to SMALL engines to throw turbos on... - crcrExplorer
drsteve wrote:
Grit dog wrote:
Bingo! I’ve had the diesel bug ever since they quit being pieces of chit and actually started putting down some power.
But a twin turbo eco boost type V8 making somewhere around Hellcat numbers would get me to rethink my diesel decisions!
The small displacement EcoBoost is used because trucks are coming under increasingly strict fuel economy regulations. A big gas V8 will get lousy mileage both on the boost and not on the boost. If you want big power from a V8, just make the pistons bigger. It's cheaper than a turbo.
3/4 and 1 ton trucks are exempt from EPA mileage disclosure requirements. And anyway, re fuel economy regulations, they are NOT being made more stringent, instead they are being scrapped, linky link.
Further, I don't care if larger pistons are cheaper than turbos, my potential interest in a gasser for towing would be in a turbocharged V8. Engines with turbos are much less subject to power loss due to altitude, and generally have a torque curve more suitable for towing than naturally aspirated engines. - ppineExplorer IIII have spent the last two days running a diesel excavaltor in my yard. It is a small Kubota with a back hoe and a blade. It only weighs 4,000 pounds but got a ton of work done. I used 3 gallons of fuel. This is exactly how other countries get their work done.
- drsteveExplorer
womps wrote:
ShinerBock wrote:
And I wonder how gigantic the grille would be to cool such an engine under heavy load.
Probably as big as the new Toyota and Lexus cars and suvs!
Those things look like the factory forgot to install part of the front end. - drsteveExplorer
The small displacement EcoBoost is used because trucks are coming under increasingly strict fuel economy regulations. A big gas V8 will get lousy mileage both on the boost and not on the boost. If you want big power from a V8, just make the pistons bigger. It's cheaper than a turbo. - Grit_dogTrailblazer
But a twin turbo eco boost type V8 making somewhere around Hellcat numbers would get me to rethink my diesel decisions! - wompsExplorer
Probably as big as the new Toyota and Lexus cars and suvs! - ShinerBockExplorer
And I wonder how gigantic the grille would be to cool such an engine under heavy load. - captnjackExplorer
Me too. - crcrExplorerI'm wondering when one of the Big 3 US truck manufacturers might market a gas V-8 with turbo(s) in their 3/4 and 1 ton pickups. That's one gasser I would consider for towing ...
