sgrizzle wrote:
thoughts on "panel adhesives"? our shower accordion door seems looser than i'd like. I was thinking about shooting some adhesive to shore that up...should be fine, right?
I have used Loctite PL-Premiun construction adhesive and the stuff is amazing. I used some when I replaced a sheet metal shield under my motorhome. It had about a 1" x 8" lip on it that fastened to the sub-floor. Recently I had to remove it. I could not get it off. I had to heat it up with a torch to soften up the adhesive. It typically is packaged in a caulking tube, but I have seen it in a small squeeze tube. Of course the small tube costs almost as much as the large caulking tube.
