Walaby
Oct 14, 2016Explorer II
FishOnOne wrote:Walaby wrote:FishOnOne wrote:
And that F150 doesn't have a DEF fill port right next door to the diesel fill port either just waiting for a spill to occur. I would most definitely have the MOPAR diesel protective cap.
An accidental spill? I've got a Ram CTD, and yes, the DEF port is next to the diesel fill port, but OMG, I can't imagine an accidental spill that would create an issue. Good grief..... just when you heard it all.
But, considering the source, Im not surprised.
Mike
If you "can't imagine an accidental spill" then why do you use the green plug?
Obviously enough concern has gone around that both ram and the aftermarket has produced a cap. Some here in this thread use a cap as well.
When I bought it (used), the green plug was there.. saw no reason to throw it away.
Even if it was gone, see no concern/reason why the DEF would accidentally spill all in the tank.. With enough to actually cause a problem. Haven't spilled a drop of DEF yet.
I don't believe they made the plug because they were worried about an accidental DEF spill.
Mike
