drittal
Oct 17, 2016Explorer
Perrysburg Dodgeboy wrote:
Well don't know what to tell you all but mine doesn't drip a drop of diesel on the ground. Hell in almost every state you can be fined for spilling fuel on the ground! Look it up! So do you think FCA/Ram or any other manufacture would design a filler tube that would allow fuel to spill on to the ground!?
Don
Because it's not designed to spill fuel on the ground. It is designed to prevent water or other spilled materials from entering the fuel tank.
It should never spill fuel on the ground unless you are filling improperly.
It should never spill DEF on the ground unless you are filling improperly.
Even of you did, in the very unlikely circumstance, get fined for a minor spill it is a hell of a lot cheaper than replacing your fuel system.
