otrfun
Oct 17, 2016Explorer II
Walaby wrote:Believe I'll pass on the paper towel tip, Mike. Thanks though. The aftermarket fuel cap (and o-ring) will provide sufficient protection for my needs :W
Make sure you wipe the pump nozzle off with a paper towel before you put it in the tank. There might be dust or dirt particles on the nozzle that will definitely get into the tank and through the second flap.
On second thought.. better not use a paper towel, as paper particles and dust might get in. Not sure which one is worse.
Mike
FYI, to put this aftermarket fuel cap discussion in perspective for those that may not be aware, dirty injectors are not covered by the Ram Cummins basic or powertrain warranty.
