drittal
Oct 22, 2016Explorer
Bumpyroad wrote:drittal wrote:Perrysburg Dodgeboy wrote:
I don't know why you or anyone else thinks spilling any amount of fuel on the ground is a good idea and if the EPA catches wind of this I bet we will be seeing a recall on this system. If in fact they do let fuel spill on the ground. Even if it was caused be operator error or not.
You could accidentally spill fuel on the ground by grabbing the handle before it's in the fuel neck, but the EPA isn't cracking down.
The system will not spill fuel unless there is operator error.
and then it is designed to do so?
bumpy
It is designed to keep water from entering the fuel system.
If you incorrectly fuel and cause a spill that is on you, not the manufacturers.
