Bedlam's avatar
Bedlam
Moderator
Jul 02, 2022
Field tricks to remove inside dually wheel?
10 hrs waiting on emergency service for an inside DRW flat. What's the trick getting them free? I have the truck up on a 12-ton bottle jack and the outer removed. Inside is stuck to the hub even though it was off less than year ago.
  • Geo*Boy wrote:
    Wow Bedlam, my truck has never seen winter salt and never will, but the next time I have a chance I am going to pull the duals and put never seize on the hubs.
    Front too
  • Wow Bedlam, my truck has never seen winter salt and never will, but the next time I have a chance I am going to pull the duals and put never seize on the hubs.
  • Glad you solved the problem. Are you open to suggestions? Pull all the wheels, and put anti-seize on all the hubs to reduce future problems.
  • I’m interested in those pictures, Bedlam. Never encountered this issue.
  • BobsYourUncle wrote:
    I carry a lot of tools with me including an 8 pound sledgehammer. I put a block of wood across the wheel so it straddled the top of the rim and clobbered it with the sledge. It took a few tries but I eventually dislodged it. Gotta be careful not to hit the rim directly. I rotated the wheel between hits.
    Sledgehammer or pry bar, it's what the tire shops use.....
  • I found running ratchet straps through the rim and putting a wooden block centered on hub put enough even force on the rim to free it. Just when I got it free, I got a call that service was 5 minutes out. I'll post up some pictures tomorrow when we are on the OR coast.
  • Shock and awe. Hit it with some type of steel you hold in one hand and big hammer in the other. Place steel between the lugs and WHACK it.
  • I went through that a number of years ago. Try as I may, that thing wasn't coming off the hub.
    Here is how I freed mine:
    Mine was rusted onto the hub at the very back. It was the rust holding it on there.
  • You might be able to get a small steel chisel between the rotor/drum on the rim openings and give it a couple of wacks with the tire iron. it's worked for a couple of cars that had seized rims. Then apply anti seize to the mating surface, sparingly. Another trick I used on trucks if you don't have a heavy load, loosen the wheel nuts about 1/2 to 3/4 turn and make some really sharp left right turns, that often cracks them loose too.
