otrfun's avatar
otrfun
Explorer II
Jun 05, 2016
First Camping Trip with Our New Diesel
Just got back from taking our new toy hauler and '16 Ram 3500 SRW 6.7 68RFE camping for the first time. An 800 mile roundtrip to the Colorado River that included a number of steep grades and 107-115 degree daytime temps---obvious fallout from this SW US heat wave that's been on the news. The toy hauler with toys and gear onboard weighed ~12,750 lbs. with a pin weight of ~2,650 lbs.
This is our first diesel. Previous rig was a Tundra 5.7 that we used to pull a 7,000 lb. toy hauler (loaded).
This trip really drove home the diesel experience: 1) The Cummins simply pulled like a beast. Steady. Confidently. 2) The automatic exhaust brake was the cat's meow! Its operation coming down 6-7 percent grades and during normal braking on the flats was simply phenomenal. Hearing it in operation was icing on the cake. And last, but not least 3) MPG's. We maintained 55-60 mph for most of the drive--doing what we could to reduce stress on the toy hauler's China bombs in 107-115 degree heat. Overall MPG at these speeds, hand calculated, was 11.1 MPG (EVIC displayed 12.0). Considering the tow weight (almost 13k) and the constant elevation changes---11.1 MPG was a pleasant surprise to say the least. The same drive got us 8.5 MPG with the Tundra.
The only concern we had on the entire trip was a short, 4-5 mile climb (on a secondary road) that resulted in a spike in tranny temps. Speed was limited to 25-30 mph (due to switchbacks) on grades that I would estimate to have been around 7-10 percent. Turbo boost hovered around 15-20 PSI for most of the climb. It didn't take long for the radiator fan to activate--hard not to notice---it's loud. In any case, tranny temps (while staying in the same gear for the entire climb) spiked to 195-198 degrees (flat towing it's typically 168-172).
All in all an awesome first camping trip with our new rig.
  • I have the same truck except a 2015. I too am pleased and excited every time I hook up and tow. As far as tranny temps, I don't think that's to bad towing that weight under the load you were under and the speeds at which you were traveling. There really wasn't much air flow going through the coolers to make much difference in temps, plus the outside temps being what you stated, hence the fan activating to cool things down. You'll enjoy it more and more every time you tow!
