gmw_photos
Jun 12, 2014Explorer
ER Alaska wrote:
According to the literature that came with the TT, I have a Parallax 7300 Series converter. Not knowing if the following offers any useful information, the literature says that the converter input can't be any more than 30 amp, that the converter may (or may not)have an optional timer feature which is designed to lower the converter output voltage to approx. 13.5 volts 13 hours after the 120-volt shoreline power has been applied. Apparently it starts out at 14 volts initially and then drops to keep from overcharging the battery if I have this option. With the battery out and the TT plugged in, I measured 13.75 volts at the battery cables. Don't know if that tells you anything. Is this a decent converter?
My suggestion would be to put a new battery in it, and see how things work out for your use. If you find you still need improvement, then install a new, more modern design of converter.
44,066 PostsLatest Activity: Oct 04, 2013
