CharlesinGA
Jun 02, 2019Explorer
Nice large 8cf fridge, but in the slide, adds lots of weight to the slide when operating it and that is not a good thing, plus fridges in slides require a high sidewall outlet vent which is not as effective as a roof vent.
I actually like the fold out steps, the ones that stow underneath and you flip out one step, then pull the rest out can be a finger getter, plus a hassle to operate at times. Disadvantage of the flip out type is that you MUST deploy them, even if you don't want or need them.
At 7000 lbs it probably has 3500 lb axles, and of course some of the weight will be on the hitch. I do like the 15 inch tires.
Like everything, it has good and bad points.
Charles
Charles
