Texasrvman1987 wrote:
She was only in the shower for max 15 minutes. When I noticed that it went out, the pilot was even out. Which is what I don't understand. I get that once it gets hot it goes out, but the pilot should stay on. But then again I would also think that as she's showering and using the water, the burner would stay on too. Am I wrong?
Well based on your further info, there is clearly something wrong with your pilot light. All pilot lights should stay lit once they are lit. That is how pilot lights should operate. But even if you get that problem fixed, taking a shower for 15 minutes with the water running constantly is far too long for anyone to expect to have continuous hot water from a Travel Trailer hot water heater. Your wife is going to need to change her shower habits, or get used to showering in cold water.
Why?
Let's do the math:
Say you have an efficient Oxygenics low flow showerhead. That puts out 1.5 gallons per minute. If you have a the showerhead that came standard with the travel trailer, then it probably is putting out 2.5 gallons per minute.
Oxygenics: 1.5 x 15 = 21 gallons used during a 15 minute shower.
Standard: 2.5 x 15 = 37 gallons used during a 15 minute shower.
Of course, your wife is probably not using JUST the hot water for her shower, but adjusting the temperature down with a bit of cold water as well, unless you have your water heater set to a pretty low temp. (120 degrees or lower). So let's figure that she mixes hot and cold together at a ratio of 75% hot water and 25% cold.
So the hot water usage during a 15 minute shower would be:
Oxygenics: 21 x 0.75 = 15.75 gallons
Standard: 37 x 0.75 = 27.75 gallons
The size of you water heater is probably 8 gallons. But that doesn't mean you can take 7 minute shower and keep the water temperature the same (7 minutes is the time it would take a Oxygenics showerhead to pump out 8 gallons of hot water when mixed at a 75/25 hot/cold mix). The reason for this is that as soon as you start drawing hot water from that 8 gallon tank, you immediately begin pumping cold water into the tank and lowering the temperature of all the water in the tank (and if it is from underground piping and a well, it is VERY cold). When the temp cools down to a certain point the gas or electric heating element will kick in and start heating the water back up to the assigned temperature. But cold water continues to flow into the tank as long as you have the shower on. Likely, the water heater cannot keep up. And your wife starts getting colder and colder water because the heater keeps falling further and further behind, even though it is on and trying to heat the water.
Taking a military style shower eliminates the problem in more than just one way.
1. You simply use much less water,so you don't exhaust the hot water in the tank.
2. As a result, less cold water comes into the tank, so the overall tank temp stays higher, and the heater can heat it more quickly back up to temp.
3. Because you turn off the water while you soap up, the heater has a chance to catch up and heat water with no additional cold continuously coming in. If she must have long showers, she should do the military shower first, do the soap up, and then spend as long as she wants rinsing off until the water gets too cold to become bearable.
These are just my suggestions. You and your spouse are of course, free to shower how ever you want.
