Jebby14
Jul 22, 2020Explorer
you will want anti sway and weight distribution, knock another 100 lbs off your payload for that so tongue weight around 620 lbs. Means to have 15% on the tongue you are looking for a trailer with a gvwr of 4133 lbs. doable but wont be a lot of trailer. might to better with a hybrid or popup though there are several 20 foot travel trailers that will be ok. Expect limited carrying capacity on trailers that light, will likely need to keep your gear around 800 lbs. also doable.
44,071 PostsLatest Activity: Aug 16, 2026
