jspence1
May 20, 2014Explorer
First Trip Two small issues
We had our new to us TT out this weekend for the first time and I found two things I need to address.
The first one is the check valve at the city water connection, when I filled the tank and turned on the pump water would spray out of the city water connection. I tried pushing it in and releasing it a few times and it eventually stopped leaking. Is this an easy repair or should I take it somewhere to have it fixed.
Our second problem is the thermostat it has a large temperature swing If I had to guess I would put it at 25F difference between when the furnace comes on and turns off. It would go from way too cold to sweating before it turned off. Are they adjustable? Any suggestions on good replacement if not?
Thanks for your time
John
John
