2DHoop
Sep 08, 2017Explorer II
You already own the tow vehicle, and I believe that it was expressed that this is your best option for a tow vehicle due to the fact that you already own it and are not in a position to "upgrade", and based upon your responses, you seem open to suggestions.
I would consider seeking advice and performing the research in an effort to determine the approrpriate trailer match for the curent tow vehicle.
For example, the shorter wheel base of the SUV (relative to a standard truck) could present limiting factors over and above the weights.
Better to comromise a bit on the trailer attributes in favor of your current options and look forward to going on trips with the family with the appropriate sized trailer (for the tow vehicle) than fretting about a less-than-desireable tow setup.
