Yeti_plus
Jul 03, 2014Explorer
Some good replies, but I just noticed the built in running boards that are under the bed. They will likely cause problems for any tie downs. When looking for tie downs, Torklift has listings for step rails that do not extend beyond cab and then a separate listing for step rails that go to the rear wheels. You might have to cut a hole for the removable part to fit through.
Good luck, with a little work I'm sure you can make it work.
Brian
Brian
44,056 PostsLatest Activity: Dec 27, 2025
