Mike3
Jul 03, 2014Explorer
Thanks again folks, good info here. It is a full size long bed so that is not an issue. It sounds like the big issues to be decided are: wet/dry bath, rear/side entrance and how much I want to spend.
I'm coming from a 36" Fiver with 4 slides, 100 gallons of fresh water, 100 grey and 50 black and yes we dry camp a lot when it's cool enough we do not need A/C; which here in the mtns. is most of the time. So tank capacity is important as I'm planning some long trips. I think I read AF has higher capacity than most, is that correct.
I'm posting a couple of new pics to show the running boards. What do you guys think may be the best tie down solution?
I looked on line at Host, Adventurer and Eagle Cap however no dealers within 1,000 miles. The only brands within 200-300 are AF and Lance. I'm pretty sure I'd like a passenger side slide; one that allows access when closed if possible. Do either of the two above offer this layout? What other layout issues should I be considering?
44,056 PostsLatest Activity: Dec 27, 2025
