Buzzcut1
Apr 21, 2019Nomad II
had a rear tire blow out on my SRW with a 4600 pound lance 1055. The blow out and getting the rig safely stopped is the issue. Changing the tire isn't. As long as you have a good bottle jack ( not the OEM Jack) changing the tire with the camper on or off is the same thing. loosen the lug nuts, drop the spare and pull it out. jack the truck up remove the lug nuts and flat. put on the spare tighten the nuts lower the jack, torque the lug nuts stow the flat and off you go.
44,065 PostsLatest Activity: Apr 13, 2026
