mkirsch
Apr 23, 2019Nomad II
When my truck had a flat, it burst into flames, caught an edge on the road, launched into the air briefly, then came down and bounced end over end across the median, right into the path of a busload of orphans and nuns, killing everyone.
Seriously, you pull over and change the tire. True blowouts are so rare that if you aren't grossly overloaded and put new tires on at least every 5 years if not sooner, you may never experience one. Even if you do, don't panic, and everything will be fine. It might get exciting for a brief moment, but if you were paying attention to your driving to begin with, you'll take it in stride.
It is probably a good idea to dig out your factory jack and see if you can lift the truck with the camper on board, while home, and plan accordingly depending on the results of your experiment.
44,065 PostsLatest Activity: Apr 13, 2026
